Old 10-07-2015, 07:01 AM   #5
cicero819
cicero819's Avatar
Liked 69 Times in 30 Posts
Default Re: Good combination?
J. go on BBR site you will get a lot more help on there. Class racer think of bracket racer as lepers on the loose instead of saviors of Drag racing because without Bracket racing they would not be any drag racing around.lol Do you have a trans brake? If you do than it will be also a great combination.Edmond Richardson ran a 69 Camaro in S/ST and probably would have made a great S/P basically the same way you have your set up. Best combination is with seat time between man and machine. Run the car and you will see. Good Luck.CR
