Old 09-30-2015, 01:10 PM   #11
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
Default Re: Stick shift drivers by division
Originally Posted by DonatoEng View Post
Last time I ran my stick shift Dakota, I was invited to the barn to pull the trans so Tech could look at it. No one else in tear down could figure out what I was doing until I rolled out with it and put it on the bench.
Anyone else do that before ?
Shouldn't have to pull trans to find out if is clutchless, just need to go for ride with you and have accelerate in each gear and let off throttle, if it is clutchless the shifter will ratchet back and forth when you let off gas because back side of sliders and rings are ramped and will try to kick out of gear when you aren't in a pull,if you are holding shifter it will ratchet as slider an ring jump over ramps, except for high gear.
Also all the clutchless trans I have ever seen have to have rod from shifter for every gear,4 speed has 4 rods plus reverse 5 has 5 rods plus reverse.
