Old 09-10-2015, 12:46 AM   #21
Default Re: 2015 - The Indy some of us missed ! ! !
Originally Posted by Super Sport View Post
While 1970-73 Firebirds may look the same, 1973 is a unique year for the front of a Firebird. Not what shows on the outside but what is considered impact zone behind the front fascia. The rulebook says that energy absorbing apparatus may not be removed. All the energy absorbing stuff on the front of a 1973 Firebird is heavy. If it was missing, that is probably why the car was not allowed to run.
You are correct about the 73 being an energy absorbing setup behind the grill.
The car in question was a 71 earlier in the year, but was entered as a 73, so you may be right about that too.
Old 09-10-2015, 08:22 AM   #22
west coast
Liked 223 Times in 73 Posts
I believe that rule changed a couple years ago will have to look again.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 09-10-2015, 08:35 AM   #23
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Originally Posted by ALMACK View Post
One other tidbit of info about the 2015 US Nationals...
Stock Eliminator got it's first 11 second qualifying pass with an engine only firing on 4 spark plugs.
Congratulations to Mr. Buth on that one, again.
I ran an 11 second qualifying pass on 7 cylinders at Indy once. Does that count?
Old 09-10-2015, 08:45 AM   #24
Billy Nees
Liked 7,782 Times in 1,743 Posts
2015 Rulebook, section 10A,page 6; Bumpers,Energy-absorbing apparatus may NOT be removed.
It's still in the East Coast Rulebook!
Billy Nees 1188 STK, SS
Old 09-10-2015, 11:02 AM   #25
west coast
Yep still there. I found it in the PDF version on page 8
Old 09-10-2015, 01:18 PM   #26
travis sturgell 3339
The only difference in the 3 1973 firebirds were 2 had the grills and 1 didn't they brought all 3 and look at them same time. The racer admits he should have had the grilles change before. Problem is you had 1 tech guy that is a Pontiac nut who caught it. But if you do that to one guy you have to make sure every brand of car is right to.
travis sturgell 3339 is offline   Reply With Quote
Old 09-10-2015, 08:18 PM   #27
Scott Loge
Liked 145 Times in 32 Posts
Smile Re: 2015 - The Indy some of us missed ! ! !
Thank you to all that posted updates! Also to Jim B, congrats and u are the yardstick many will measure with! Indy is what it should be and congrats to all that attended! Maybe again someday, a lot of work to do
Scott Loge is offline   Reply With Quote
Old 09-11-2015, 12:36 AM   #28
Jason
Liked 6 Times in 4 Posts
Thanks to that Pontiac nut now everyone knows to be on the lookout for fake 1973 Firebirds. There seems to be a lot more to making a 1973 Firebird than just changing the grille.
Jason is offline   Reply With Quote
Old 09-11-2015, 09:23 AM   #29
Dick Butler
Liked 32 Times in 19 Posts
And when Farmer was there.... Go to a junk yard and get the lens cover for the dome light and return to tech to prove you have it before you can get tech card..... did it and got teched..
Old 09-11-2015, 10:11 AM   #30
a pontiac
Liked 36 Times in 11 Posts
the problem.... remaining 2 fb's are converted 70-72s w/73 grilles and multi event winners over several seasons.
a pontiac is offline   Reply With Quote
