Liked 20 Times in 15 Posts
I have F/X 28.5 x 9 tires for my Nomad. I started with 7 inch rims, because that is what I had. I see most guys are using a 10 inch rim.
8 & 10 are the two most common widths and availability. what effect does the rim width have on the tire [center section, tread width and height-both setting and at speed]? std. trans, 105 at the line given a choice, what is best? thanks, Rod in AZ |
Liked 138 Times in 51 Posts
A wider rim will allow more air pressure while maintaining a fuller/wider "footprint" over a narrower rim. A tire will also grow less at speed with a wider rim. Higher air pressure also reduces sidewall "wrinkle", which helps it last longer and can help the car be more stable at the top end.
A wider rim will increase the section width a bit. Each car/combo should still be tested to see what air pressures will work the best because of the many variable. On the same rim, a radial slick will grow less than a bias ply because of their construction. So you may have to adjust your gear ratio accordingly. But radials aren't normally recommended for stick cars.
LOCOMOTION Racing Last edited by Myron Piatek; 09-08-2015 at 12:13 PM. |
