#71 |
Liked 32 Times in 7 Posts
Stock Q1 is in the books.
There is still some housekeeping to be done as far as cars in the wrong class and driver info not entered so these numbers are likely to change. So far, I've got 24 cars in the Factory Stock Showdown but that number is almost certainly higher. It might even be as many as 30 since a handful of new cars ran without their data entered. Chris Holbrook killed it in FS/XX with an 8.560 (9.90 index) but there is a good Ford-Chevy rivalry there since Clay Arnett is only a couple hundredths back with an 8.589. In FS/X, David Barton's Mopar lowered the boom with an 8.804 (10.15 index) I believe Barton is currently the low qualifier. I'll clean up some of these numbers once the cars clear the scales and the we get an official qualifying sheet. More later... |
#72 |
Liked 10,837 Times in 2,252 Posts
Kevin, thanks for updating everyone! Yes, Roy Hill got the wheelie award for the session! I am just glad he was running a much slower car or it could of been ugly!!
We are tickled to death with our run! 1.07 under in B/SA! I think he got it fixed! 178 cars went down, with Steven Dzoriny getting shut off on the line. He later went down in front of the stands so maybe leaking something?? A few wrong indexes, so it will take a little while to get things up. More later |
#73 |
Liked 16,819 Times in 1,538 Posts
Yes Kevin, thanks so much for pitching in. Here are some photos from the staging lanes while stock was running the first round qualifier. The weather for the first round was, well lets just say it was typical Indy.
Temp 77 Humid 70% Bar 29.19 DA 2982 wind cross 2 to 4 mph |
#74 |
Q1 Sheet in hand here's what we've learned so far.
177 cars made runs David Barton leads with a (-1.346) 8.804 in his FS/X Dodge Chris Holbrook No. 2 (-1.340) 8.560 in FS/XX Cobra Jet Clay Arnett No. 3 (-1.311) 8.589 in FS/XX COPO Top three cars are Dodge, Ford, Chevy 28 cars officially in Factory Showdown Quickest "traditional" stocker is Jim Hale's H/SA Fury (-1.164) good for No. 9 128 car bump is Matt Kennedy at (-.804) 38 cars a second under or quicker 15 cars in B/SA 8 cars in A/SA 19 of top 21 are new cars Top speed is Bruno Massel at 159.82. Super Stock up soon More later... |
#75 |
Liked 372 Times in 130 Posts
Thanks for all the updates and great pics !
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#76 |
It is mineshaft conditions!!!
#77 |
Super Stock Q1 early report
Ray Skillman No. 1 21 Hemi Cars took the tree (might be one or two not on the sheet) Wolkwitz 8.554 Bucky 8.581 Hebert 8.589 P.B. Candies 7.957, 168.72. I know it's not the quickest Super Stock run but there is still something impressive about seeing a 7-second E.T. during a Super Stock session. Best pair/photo opportunity: Fred Henson's '68 Dart vs. Dallas Kelly's '64 Thunderbolt. Two incredible cars. |
#78 |
Liked 325 Times in 50 Posts
It is a solid .12 to .16 slower than Bowling Green 92 grains water. Barometer is so low, a hurricane has more pressure than in Indy today. Track is a little tricky, but most made it down.
Jeff Teuton 4022 STK |
#79 |
I bought a E/SA Camaro over the winter and understood the factory stock COPO s etc wouldn't screw up the eliminator any longer but looks like I'm wrong. What a crock if you want to spend 150,000.00 and up,or in many cases get it free, for a store bought killer factory stocker ,which by the way has 4 link rear,coil overs and need I go on. Now there are a lot of great stockers at Indy that will sit out eliminations because these cars eat up 30 and more of the 128 spots. Only good news you don't have to run them in class but that's as far as most will go this year. 1.3 under will they get HP or not?
#80 |
Liked 93 Times in 52 Posts
Stock is up again.
https://www.nationaldragster.net/bit...audiocast.html |
