What size tire can the car fit? I ran an 81 Malibu with a 250 horsepower 327. It had a 4gc carb and ran it with a 31.25 X 12.2 tire. I probably could have run it with a smaller tire, but with some marginal tracks I chose the larger tire.
If you run a big block, the torque you make with necessitate a 14 X 32 tire. I built the car with a 9 inch and 4-link. You could run it with a ladder bar, but it isn't as adjustable. With the stock suspension, you would need an anti-roll bar and adjustable control arms. Then, tire size would dictate the motor you could run. Hope this helps. Jeff 6990 SS/MA |
