Old 06-03-2015, 10:34 PM   #1
Liked 5,125 Times in 1,953 Posts
Default Re: '66 Malibu N/SA
Dave, You might want to consider using Aluma Lead filler in that area.
It's harder to sand and gummier on your paper, but it resists water better than regular Bondo.
Not that you'll be driving in the rain, but on the burnout you know...Might not hurt.
Comes in quarts too.
Old 06-03-2015, 10:50 PM   #2
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
I'll check into it, wouldn't hurt to give it a try.
Dave Muller is offline   Reply With Quote
Old 06-03-2015, 11:56 PM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
You can probably borrow some wheels/tires of both backspacing to test fit. These will be pretty common to find. I really like the '66 body style.
Rich Taylor
I/SA - 321
Old 06-04-2015, 12:26 AM   #4
Dave Muller
That looks gorgeous!
I have always thought that 66s were the best looking Chevelles.
I already have the tires and wheels. I took enough measurements to convince myself that 5.5" backspacing was the way to go. Still don't have the backing plates back, and I won't be verifying the tire clearance until then, but I'm pretty sure it'll work. May or may not take a little persuasion. The fact that the same size works for Mark Faul helped convince me as well. The wheels I used for taking measurements were close to that offset as well.
Old 06-04-2015, 12:42 AM   #5
HandOverFist
If you need backing plates Dave we may have some lying around.
Rich Taylor
I/SA - 321
Old 06-04-2015, 01:32 AM   #6
Dave Muller
I have them but they need to have the holes opened up to fit the larger bearings in the axles on the Moser rear. With a little luck I'll have them back Friday.
But I'll keep you in mind if I have something along those lines that comes up.
Actually, I am missing the kick panel vent for the right-hand side. The one that's controlled by a knob via cable. The car only came with the left one. But I'm sure I'll track one down somewhere.
Old 06-13-2015, 12:29 PM   #7
Dave Muller
At this point I have the patch panel welded in with one of my usual ugly welds, and I'm most of the way through grinding the welds down. Of course if I were a better welder I'd be done with that now! And damn, MIG welds are hard!
But this morning I test fit the slicks. Later today I'll put the jack under the rear to move the tire up into the wheel well in case that results in a tight spot I haven't seen yet, but so far it looks pretty good. The front bottom corner is a little tight. I am considering trimming that back a bit:
It looks like I'm a bit limited to how much I can lower the rear but I think I'll be okay here too:
Finally the inside looks like about 3/8" minimum clearance. I might consider a very thin spacer to move it out just a bit depending on how the outside looks when I jack up the rear:
I also might have to tweak that body mount behind the tire just a bit, but I suspect that will not be necessary either.
