Liked 223 Times in 73 Posts
At this point I have it trimmed about the best I can, so I went ahead and welded it in:
![]() Last edited by Dave Muller; 07-07-2017 at 08:30 PM. |
Liked 5,120 Times in 1,951 Posts
Dave, You might want to consider using Aluma Lead filler in that area.
It's harder to sand and gummier on your paper, but it resists water better than regular Bondo. Not that you'll be driving in the rain, but on the burnout you know...Might not hurt. Comes in quarts too.
I'll check into it, wouldn't hurt to give it a try.
Liked 33 Times in 16 Posts
You can probably borrow some wheels/tires of both backspacing to test fit. These will be pretty common to find. I really like the '66 body style.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 06-03-2015 at 11:58 PM. |
That looks gorgeous!
I have always thought that 66s were the best looking Chevelles. I already have the tires and wheels. I took enough measurements to convince myself that 5.5" backspacing was the way to go. Still don't have the backing plates back, and I won't be verifying the tire clearance until then, but I'm pretty sure it'll work. May or may not take a little persuasion. The fact that the same size works for Mark Faul helped convince me as well. The wheels I used for taking measurements were close to that offset as well. |
If you need backing plates Dave we may have some lying around.
Rich Taylor I/SA - 321 |
