Old 04-29-2015, 08:05 AM   #11
Ed Wright
Ed Wright's Avatar
Default Re: Hurst 3 Speed Shifter For Metric Forward Pattern
After owning a Precision (PPP) shifter, I would not consider anything else.
Ed Wright 4156 SS/JA
Old 04-29-2015, 09:25 AM   #12
jmcarter
jmcarter's Avatar
PPP is a slick shifter, just have always used a TurboAction because with optional gate plate(s) it can be used on about anything and cable direction can be changed very easily (as well as air shift solenoid). Paul also has a "informal" contingency program.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 04-29-2015, 10:29 AM   #13
Rusty Davenport
Liked 101 Times in 27 Posts
Hey Ed, please elaborate on how this wonderful shifter functions......it has a "lever" too from the picture---is it squeezed on any of the shifts ??? Does it have a detent for each forward gear that prevents shifting past the gear----please elaborate on functional operation......inquiring minds want to know ???
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 04-29-2015, 10:38 AM   #14
gbur
Originally Posted by glen myers View Post
Maybe Hurst can make a special "old guys" unit you can just put in "D"...
us old guys
Gary Burr IHRA MEMBER # 1958 Stk 1949
gbur is offline   Reply With Quote
Old 04-29-2015, 11:56 AM   #15
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
Super easy to use. They are gated so you just move it forward, it shifts and locks in. You only squeeze to put it in 1st gear or downshift. Just a small bump forward and its in the next gear. Super smooth and after using one its hard to want to use anything else. Reverse lock out requires pushing the top down with your thumb and squeezing the handle.
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 04-29-2015, 04:28 PM   #16
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Rusty - I made a video this afternoon of the shifter in action. I'll post it here when I get home from work. Pretty much bullet proof and no fumbling with levers or worries about over-travel.
Rich Taylor
I/SA - 321
Old 04-29-2015, 09:34 PM   #17
Ed Wright
Ed Wright's Avatar
He pm'd me also. Hope my response made sense.
Old 04-30-2015, 01:30 AM   #18
HandOverFist
Here is a short clip of the PPP shifter action...this a C4 w/forward pattern valve body.
Rich Taylor
I/SA - 321
