#91 |
Liked 52 Times in 9 Posts
before you restore dash cluster, not that it matters you have a Plymouth cluster the
dodge has the rectangle speedo, I have a heater delete panel if you need one. Jim
Jim Morgan 1916 , 9916 STK |
#92 |
Hy Jim! the cluster in the Dodge was the original that came in it. Do not forget ,it's a canadian car.Sometimes, there are different things you can find. when i did that car in 1999,I put back the complete original dash in it.The only thing i change was the trans push button trim plate, i install a delete platefor the push buttons and a delete radio plate.
#93 |
Canadian built could be the difference It is A very nice car I had a 64 dodge alum 440 mod.
#94 |
Liked 529 Times in 36 Posts
Canadian cars built in 1963 and 1964 had USA Plymouth dashes in them, as well of you try to decode the VIN it will show that it doesn't exist. As well the standard V8 was a 313 and not a 318. It will give everyone at the track something to argue about.
Darcy Clarke A/SA SS/ JA Last edited by Darcy Clarke; 03-05-2015 at 03:30 PM. |
#95 |
Liked 64 Times in 11 Posts
Help! Hood springs? Where can I buy new hood springs? 50 year old springs just can't keep the steel hood up!
#96 |
I may have some 50 year old ones if you want to try them
#97 |
Liked 10,779 Times in 2,240 Posts
Indy fast approaching! Is it going to be the mopar or the ford in stock, I hope you bring one of each.
#98 |
The Ford is getting a engine freshen job now. Funny thing about ring seal, if you don't have any it's slow! Tibor will drive the Tbolt. The hemi is still in Phoenix.....and I don't have enough stock points to get in! So we are planning on going with Tbolt and G5.
#99 |
Tom my guess will be a grade point of one will get you in to Indy in stock. It will hot and humid but will still be mineshaft conditions at the big go.
#100 | |
It would be really cool to see the Hemi car! I've been following this build since the beginning.
Jared Jordan 9 B/SA 2024 Jeg's D7 All Star - Stock |
