I have heard different things, but how should a ladder bar car be set up as far as the angle of the bars. I have heard level, down, and a few say up. what is right.
This is a 3000lb car w driver that has ladder bars/coil overs with Qa1 single adjustable shocks on the rear a 29x10.5 slick and runs 6.60's in the 1/8th mile NO trans-brake What spring should it have I have heard 110 and 130. where should the shocks be adjusted to start with. |
Liked 1,943 Times in 584 Posts
set your ladder bars up with 2 degree down angle with respect to the bottom of the rocker panel on the car. put a protractor or smart level on the rocker panel see what degree that is and make the bottom bar on the ladder bar 2 degrees more down angle. put 2 degrees down angle on the pinion. My car weighs 3165 and I have the same type shocks as you. I run 110 lb springs. I run my shocks 2 clicks from loose
Mike Pearson 2485 SS |
Liked 320 Times in 102 Posts
Hi,
I think that any racer who wants to work on their suspension owes it to themselves to buy Door Slammers: The Chassis Book by Dave Morgan... A very good read with a ton of info..... I bought mine over 20 years ago..... Bob
Bob Mulry 7516 STK A & M Motorsports Last edited by Bob Mulry; 04-05-2015 at 04:19 PM. |
#4 | |
Liked 33 Times in 16 Posts
Rich Taylor I/SA - 321 |
The book is only $43 on Amazon, hard to beat.
Liked 99 Times in 60 Posts
Hard,
The setup Mike presented has worked well for me with three different cars. [the slightly down position] I "think" with the average, slightly front heavy door car, that is a good setup. In addition, a rear anti-roll bar will change a very good working car to an excellent package. With three different situations, I have personally experience cars that were very consistent become copy machines with the addition of a rear anti-roll bar. [all three ladder bar setups] A 1990 Firebird that I campaigned for several seasons with the above setup could and did win without changing the dial in over a race of 7 - 8 rounds. It ran an average ET 6.15 in the 1/8th.
Larry Woodfin 471W |
#7 | |
Liked 7 Times in 6 Posts
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
No. The preload pulls the front of the ladder bar up.
Marty Rinehart Jr 1125 SS STK SG SC SST |
No pre load!!! Because for every action there's a reaction.
I have qa1 single adjustable shock on the rear. my question is every time I tighten the shocks up the car works better. they have 12 adjustments I am at 7 from soft. car works better every time I tighten them, but it rides like a old haywagon. would like to get the car just a bit better should I tighten them even more or should I move the bars down one hole and loosen the shocks up some at this point.
