Old 03-25-2015, 10:06 AM   #3
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: advice on purchasing correct scan tool
Misfires with O2 codes are typically linked, what I see the most is the O2 will shift either full rich or lean and induce a rich or lean misfire. Are you seeing the misfire on the same bank as the O2 codes? Does it seem like it starts running worse after it's ran for a few minutes? If so the O2 is probably skewed and once it enters closed loop it begins to alter the fuel trim which will make them run rough, any good scanner will allow you to view this data. Joe
Joe Buchanan SS/BX 3117
