Old 02-14-2015, 07:53 PM   #7
Vinnie78
Default Re: 77 nova stock or s/stock st or auto Help!!!!
Tell us more about the Muncie.
No reason why you couldn't run a Muncie in T/Stock ...if it had enough low gear in it.
The transmission I have is the 252 first gear wide ratio box from a 65-67 GTO withe two groves on the input shaft . I was figuring at least 4.88 rear gear with that . What do you think ???
Vinnie78 is offline   Reply With Quote
