Old 02-09-2015, 01:26 PM   #11
MR DERBY CITY
Liked 8,047 Times in 1,528 Posts
Default Re: Fuel change from VP to Sunoco
Don't sweat it 4543...Drain all your fuel from the cell. Open the cap to allow the foam to air dry as long as possible, put a small amount of new fuel in (1/2 gallon)....undo the fuel line at the carb and run the small amount into a fuel jug and discard. You have successfully Douched your fuel system..LOL !!"."........M.J.
Old 02-09-2015, 04:19 PM   #12
asmyth1783
I was speaking to some of the tech guys at Pomona, and they said that they are going to be very lenient with fuel at least for the first few races. The sportsman classes are still allowed to run VP, we just won't be able to buy fuel at events.
asmyth1783 is offline   Reply With Quote
Old 02-10-2015, 07:34 PM   #13
Mike Croley
The Sportsman classes can run a number of race fuel brands including Renegade. All of the fuel info is available on the NHRA web site under accepted products list.
Mike Croley is offline   Reply With Quote
Old 02-10-2015, 08:15 PM   #14
monahan
Liked 5 Times in 2 Posts
I have a chance to try some renegade fuel what is close to c12 to compare performance any suggestion ??? Thanks gene sorry for hijacking the thread
monahan is offline   Reply With Quote
Old 02-10-2015, 08:32 PM   #15
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
I don`t understand why people aren`t doing what some of have had to do when Sunoco became unavailable at Nat`l events a long while ago,bring extra to the track from home instead of changing brands? I`ve heard different brands are a different tune up.
Lane Weber
Old 02-10-2015, 09:14 PM   #16
Mark Faul
Liked 43 Times in 9 Posts
Gene, I switched recently from C12 to Renegade 110. Didn't notice any difference in ET. Much cheaper too. Fuel check has never been a problem either.
Mark Faul is offline   Reply With Quote
Old 02-10-2015, 09:53 PM   #17
monahan
Thanks for the info mark I am going to give it a
try price wise looks good. Thanks gene
Old 02-10-2015, 10:12 PM   #18
DIV3CR
Liked 3 Times in 1 Post
Question Re: Fuel change from VP to Sunoco
I was told to throw away the foam, its a accident waiting to happen.
Can you use Sunoco from last year if its in a plastic jug with the cap
tight. Thank you.
DIV3CR is offline   Reply With Quote
