Liked 8 Times in 6 Posts
For those who will attend the National and Divisional at Wild Horse Pass in Phoenix and use Sunoco Purple(110) you can save $2.50 a gallon if you buy it across the freeway at the Loves gas station. It is $7.49 a gallon. I have used it for the past 5 years and have never failed a fuel check.
Raul |
Liked 646 Times in 140 Posts
I am a little concerned about switching fuels. My fuel cell has never had anything in it except C11 and it does have the foam in it. Guess I will just try and flush and see what happens. Thanks for the responses.
Liked 7,941 Times in 1,520 Posts
Don't sweat it 4543...Drain all your fuel from the cell. Open the cap to allow the foam to air dry as long as possible, put a small amount of new fuel in (1/2 gallon)....undo the fuel line at the carb and run the small amount into a fuel jug and discard. You have successfully Douched your fuel system..LOL !!"."........M.J.
I was speaking to some of the tech guys at Pomona, and they said that they are going to be very lenient with fuel at least for the first few races. The sportsman classes are still allowed to run VP, we just won't be able to buy fuel at events.
The Sportsman classes can run a number of race fuel brands including Renegade. All of the fuel info is available on the NHRA web site under accepted products list.
Liked 5 Times in 2 Posts
I have a chance to try some renegade fuel what is close to c12 to compare performance any suggestion ??? Thanks gene sorry for hijacking the thread
I don`t understand why people aren`t doing what some of have had to do when Sunoco became unavailable at Nat`l events a long while ago,bring extra to the track from home instead of changing brands? I`ve heard different brands are a different tune up.
Lane Weber It`s Not What You Drive That Wins....It`s How You Drive It |
Liked 43 Times in 9 Posts
Gene, I switched recently from C12 to Renegade 110. Didn't notice any difference in ET. Much cheaper too. Fuel check has never been a problem either.
