If your converter flashes 5200 with a 4.33 gear and you swapped to a 4.71 how much would that tighten the converter up.
#2 | |
It MAY act a bit tighter off the line, but how much? Some ..maybe Anybody that tells you more specifically than that is just guessing.
Liked 880 Times in 311 Posts
What Mark is saying is converters react to load. Static is always static, but at the initial car move the load on the converter is different due to the gear multiplication. It is more apparent with gear changes in the tranny than rear gear changes. Too many variables to guess. That is what data logging and testing is for. If you change the gear and don't pick up it might not be the gear ratio that doesn't work. It might be the converter doesn't like the less load of the steeper gear. Talk to "Your" converter guy. He should know how your converter is built and should be able to give you a SWAG....
Adger Smith (Former SS) |
Let we ask another question. If you have a converter and it is to loose for your combo, and your put the right converter in.
Would your 60ft pick up or slow down. |
#5 | |
That is with everything else being up to snuff...Suspension, carburetion, etc.
Liked 584 Times in 94 Posts
Hardtimes: exactly why I quit worrying about 60' times years ago. ....My car will 60' like crazy when the convertors too loose. I set my cars up using 330' times. - JB -
Liked 7,783 Times in 1,743 Posts
Regarding 60 ft times, Jim Beattie hollared at me a long, long time ago about that. His exact quote was,"Why the he** are you so worried about your 60ft times, is there somebody standing out there handing out $100 bills?"
I would work on the first inch more than the first 60'. If it doesn't move the first inch all else is not relevant.
Another point is ..Too loose is usually more consistent.
Sponsor
Liked 9 Times in 1 Post
We have found in our own testing with the Challenger that each rear gear ratio change is roughly 150 rpm, when all else remains equal. So you could be as much as 300 tighter.
