Old 02-05-2015, 09:16 PM   #3
Dickens
Liked 12 Times in 8 Posts
Default Re: Optispark question
The rotor is mounted on the code wheel and a thin spacer. Although the spacer is small, I think it is best to leave them in place.
You may also want to consider tack welding the optispark drive shaft to the rotor mounting. The phase is typically off due to the pressed parts turning on the shaft.
DDD
Dickens is offline   Reply With Quote
