Old 02-03-2015, 05:48 PM   #231
7423
Default Re: Ford vs Chevy Build-up
Originally Posted by HandOverFist View Post
I figured my solution would be beyond question...everything is as factory produced.
Are you doing a fresh race motor or starting with what came in your car??
7423 is offline   Reply With Quote
Old 02-03-2015, 05:48 PM   #232
Those factory air boxes are as much about sound deadening as air flow.
They can be gutted and cleaned up but the outlet is gonna still be the same size.
...And the inlet? If there's no air movement behind the headlight, as in many GM cars and trucks, then you might be better off with warmer under hood air, as opposed to a restriction up front.
Old 02-03-2015, 08:53 PM   #233
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Building this one from scratch, but using the block, heads, intake and crank.
Rich Taylor
I/SA - 321
Old 02-03-2015, 08:57 PM   #234
HandOverFist
Mark, the inlet to the box is in the fenderwell, not facing forward. As far as restriction goes I can easily do a back to back comparison once up and running.
Rich Taylor
I/SA - 321
Old 02-03-2015, 11:53 PM   #235
Cool Re: Ford vs Chevy Build-up
No, I realize this . I had a 91 at one time.
I was asking mainly because of a Chevy I have here .
You left the door open cuz you have Chevy in your title.
In other words, I wasn't really hijacking your thread.
Old 02-04-2015, 02:18 AM   #236
HandOverFist
The only problem I see with the air box is the limited (3"X6") inlet vs a 360 degree surface area of a conical filter at the end of the tube such as Jerry's car. As far as heated air ingestion from the filter location vs the somewhat isolated air box...I suppose in the end it will probably be a wash in terms of performance. There appears to be no hard and fast rule regarding induction plumbing when it comes to these efi cars judging from previous posts.
Rich Taylor
I/SA - 321
Old 02-04-2015, 12:05 PM   #237
Dave Gantz
Liked 251 Times in 125 Posts
Evan Smith's car runs hard and he has been running it for a long time. Maybe you could pm him and see what he thinks.
Old 02-06-2015, 09:31 AM   #238
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
The engine photo I posted is Evan Smith's 93 Cobra R stocker.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 02-06-2015, 12:53 PM   #239
Dave Gantz
There ya go. Thanks Jerry.
Old 02-27-2015, 09:33 PM   #240
HandOverFist
Spent the day tying up loose ends. Added a quick release steering wheel...what a difference it makes easing entry/exit. Fuel lines run and secured. Next is mounting the fuel cell and weight boxes.
Rich Taylor
I/SA - 321
