Old 01-21-2015, 09:15 PM   #211
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Woodfin's SS GT/TB construction series
In other photos you will see the master switch mounted through the bed wall and the "on/off" rod comes out through the taillight.
I also want a control level within drivers reach. This shows a test fit cable through the fender down to the switch lever. The final cable will be about 10 feet in length and mount near the shifter.
And speaking of shifter, because the truck floor and seating is taller than a car by about 4" we need a shifter mounting platform. This shows a mock up of shifter "extender platforms" that will mount the shifter in just the correct spot. It will also incorporate the master cutoff drivers control lever.
Question, do some of you share my "loyalty" to some items. This shifter and air shift solenoid have been with me in five different buildups. I find comfort in having on-board components that are proven winners and proven reliable.
ID:	27014   Click image for larger version
Larry Woodfin 471W
Old 01-23-2015, 05:09 PM   #212
Dragsinger
Tomorrow is paint day. Come on shiny black paint.
And even better news, no more fitting and welding and grinding to install custom items then removing them.
After tomorrow the parts go on to stay. We will have some sitting outside on all four tires photos soon.
ID:	27100   Click image for larger version
Larry Woodfin 471W
Old 01-24-2015, 08:00 PM   #213
Dragsinger
Today was shiny paint day. I like shiny paint.
ID:	27113   Click image for larger version
ID:	27114   Click image for larger version
ID:	27116   Click image for larger version
ID:	27117   Click image for larger version
Larry Woodfin 471W
Old 01-24-2015, 09:19 PM   #214
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
You know your getting close when your spraying color.
Well done!
Old 01-24-2015, 09:30 PM   #215
Dragsinger
Glenn, yes, the parts no longer have to be taken off after fitting. They can now stay on. We will have a roller in just a few days
Larry Woodfin 471W
Old 01-25-2015, 08:30 PM   #216
Dragsinger
We had a very productive weekend! We are rolling Check the "stance"
ID:	27152   Click image for larger version
ID:	27153   Click image for larger version
ID:	27155   Click image for larger version
ID:	27156   Click image for larger version
Larry Woodfin 471W
Old 01-26-2015, 09:25 AM   #217
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Like X 2!!!
Dwight Southerland is online now   Reply With Quote
Old 01-26-2015, 08:58 PM   #218
Ronnie Smith Jr
Ronnie Smith Jr's Avatar
The stance looks great. thanks for the pics and good luck with the remainder of the build.
Ronnie Smith, Jr.
Ronnie Smith Jr is offline   Reply With Quote
Old 01-27-2015, 11:07 PM   #219
Dragsinger
Check my idea about MSD and fuse panel mounting. [lean passenger seat forward for access] In addition, we installed a bar to mount the switch controller and dial-in controller
ID:	27185   Click image for larger version
Larry Woodfin 471W
Old 02-03-2015, 08:53 PM   #220
Dragsinger
It's time for some updates.
For two plus weeks my main attention has been struggling with an upper repository infection. It has taken the wind out of my Super 10 building sails
The turn around has happened and I am on the upward swing so let's get back to work.
*This series of photos shows the newly upholstered factory seat
*The MSD and Digital Delay relay mounting
ID:	27234   Click image for larger version
ID:	27235   Click image for larger version
Larry Woodfin 471W
