Old 01-06-2015, 04:05 PM   #1
SSDiv6
Default Re: Reactor Flexplate Beware of this manufacturer !!!!
The best place to get the correct Reactor flexplate is from Coan racing transmissions.
Old 01-06-2015, 04:06 PM   #2
Ed Wright
Ed Wright's Avatar
What is different about it? (Reactor)
Ed Wright 4156 SS/JA
Old 01-06-2015, 04:20 PM   #3
Rich67stang
Liked 116 Times in 27 Posts
Reactor flexplates are Aluminum, I have had good luck for 10 years with them until
this past season and blew one in half @ 10k rpm. They should be changed very frequently. I went to a Meziere steel.
Richard Preiser
1613 FGT/I 1510 C/SA 161 F/DA
Rich67stang is offline   Reply With Quote
Old 01-06-2015, 05:11 PM   #4
SSDiv6
I believe you got your money's worth using it for 10 years @ 10K RPM!
Old 01-06-2015, 08:41 PM   #5
Liked 5,153 Times in 1,967 Posts
Don't think that would be a problem with a Pontiac.
Old 01-06-2015, 09:01 PM   #6
SSDiv6
I should help dampen the frequencies of that heavy, big stroke crankshaft.
Old 01-06-2015, 09:02 PM   #7
Ed Wright
Ed Wright's Avatar
10,000 RPM shouldn't be a problem. :-)
Old 01-06-2015, 09:08 PM   #8
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
I've seen the results from one that came apart shortly after it had been recertified.
The allen bolts that retain the ring gear failed and the ring gear came apart at the butt weld slicing thru the headers and frame rails of a roadster like the were made of butter.
Ive seen similar failures on steel wheels at the butt weld if it is not where an attaching weld is located ,but never with such devestating results.
I would never use one on my cars.
Old 01-06-2015, 09:31 PM   #9
Ed Wright
Ed Wright's Avatar
As light as my steel TCI flex plate is, I just don't see a measurable gain from an aluminum version.
Old 01-06-2015, 09:49 PM   #10
nolongerracing
Liked 72 Times in 27 Posts
Ever hear Rink's Pontiac in the water box!! LOL
nolongerracing is offline   Reply With Quote
