Old 12-30-2014, 03:28 PM   #1
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Default Re: Fwd chassis versus RWD Et
http://www.icarinfo.net/ has some good info, including drag coefficient, frontal area, and aerodynamic resistance. According to their numbers, a Dodge Stratus would be worth 15+ HP over my Volare at just 100 mph.
Old 12-30-2014, 09:23 PM   #2
mtkawboy
Liked 54 Times in 18 Posts
Aero wise at Bonneville the 4th gen Camaro looks to be better but the 3rd gen is actually the better of the two
mtkawboy is offline   Reply With Quote
Old 12-30-2014, 09:46 PM   #3
Ed Wright
Ed Wright's Avatar
I don't have one to look at right now, but can somebody that has looked both over tell is the engine is set back as far in a 3rd gen? Having to drag less tire down the track is equal to more hp. I would expect that to be worth more than the aero difference. The 3rd gens I see around here have some big tires. May just be for bracket mode?
Ed Wright 4156 SS/JA
Old 12-30-2014, 10:02 PM   #4
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
I imagine the tire companies would know the rolling resistance of their tires at different pressures. It would be interesting to know that info for the commonly run tires. I bet the rolling resistance changes for bias ply tires as they grow, radials probably don't change as much.
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 12-31-2014, 08:55 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,988 Times in 600 Posts
Ed
My buddies gen 3 firebird is at my shop. I will take a look at it when I get home this weekend and let you know where the engine is positioned. It does sit back quite a bit in comparison to my gen 1 Camaro. His engine is in the near stock location
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 12-31-2014, 09:44 AM   #6
SSDiv6
Ed
There are many of these cars that due to the engine setback with engines with a rear distributor, they have a removal cowl grill.
Old 12-31-2014, 10:00 AM   #7
Dick Butler
Liked 32 Times in 19 Posts
Next check the spindle position on an earlier vette.
Old 12-31-2014, 10:19 AM   #8
Ed Wright
Ed Wright's Avatar
I need to spend more money (no end) in a belt driven short dist up front. I was given a regular MSD for the rear. It does not come out without pulling the manifold. They come out together. Fun deal. Takes two people. Have to buy something for my Jessel belt drive to do that also. Have to buy something to run the oil pump too, don't know if it would come out alone with my Hogan intake. Easier with a single plane intake, but I could not make one run as fast.
Sure be nice to have all the money I have spent on parts that didn't run as fast. LOL
Old 12-31-2014, 04:13 PM   #9
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
wow I always wondered how much I was giving up to one of the jelly bean modifieds, after lokking the info in this link my s10 is uses 39.2hp to just to overcome aero drag at only 60mph where the c-5 vette was listed as only using 18.6 hp for the same . not sure how much that changes at 150+ . I never really thought of the s-10 being that bad? I guess I need to re-think that.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 12-31-2014, 05:10 PM   #10
Mark, The S10 has a pretty tall profile ..Look at yours in the staging lanes sometime.
You can always find it.
