Learn something every day. Don't understand aero making that much difference in ET, no faster than we run, but I don't understand how bar codes work either. LOL
Ed Wright 4156 SS/JA |
Liked 237 Times in 126 Posts
Liked 32 Times in 19 Posts
With all the variations on factoring because of stick, auto, Gt versus SS would there be reason to give a Wt break to standard RWD cars versus FWD cars in same class, or should factors apply only to FWD if that is the fast car? Leaving the HP the same on RWD?
Seems a Camaro gt versus a SS chevelle are different should it apply to this difference also? |
Liked 174 Times in 39 Posts
From all of the numbers I've seen, the 3rd gen Camaros/Firebirds are actually more aerodynamic than the 4th gens. The 3rd gen Firebirds are actually a little bit better than the 3rd gen Camaros as well.
3207 D/SA, C/ED |
Liked 328 Times in 80 Posts
I'm hoping it goes the other way for me, when and if I get this vette done. Adding 280 lbs and losing .35 on index. The Vette is lower, wider, with only slight engine set back as compared to my number 3 cylinder at spindle centerline on my FWD. On paper I'm calling a good exchange.
The only advantage I can see in a FWD car is the weight factor. Lighter is faster. There are a some aero bodies out there RWD also, so don't see much there. Dick, what are going to build? Ernie Neal SS354 |
Liked 99 Times in 60 Posts
Slightly off topic,
the last fast bracket car I build was a 1990 Firebird. It was an excellent platform, easy to work on, very very consistent. When I began the GT project I strongly considered using another 1990 Firebird and I think it would be a good package. Then became interested in the S-10 platform and went that direction. I still have thoughts of another 3rd gen Firebird before I retire or die. In my experience with 100" wheel base, strut front and easy access to engine it is a valid choice for several combinations including GT. It would also be a good IHRA Crate Motor platform.
Larry Woodfin 471W |
Liked 67 Times in 19 Posts
here is my 2 cents, if you own a rear wheel drive car, you can run normal SS, GT and the modified classes, if you own a FWD conversion car, you can only do GT and modified classes, so that's another pro and con of looking at both body styles.
Just my thoughts |
