Old 12-28-2014, 02:12 PM   #1
Jim Hanig
Liked 99 Times in 49 Posts
Default Pistons
Anyone running off set pins in their pistons,and how much.?Do you feel that theirs any power in it.
Old 12-28-2014, 03:45 PM   #2
Mike Semeniuk
Mike Semeniuk's Avatar
Liked 6 Times in 2 Posts
Default Re: Pistons
Jim I didn't see any difference. Used whatever offset Patterson sent. It was a PITA when I had to replace a couple of pistons.
Mike Semeniuk 632 GTMA
Mike Semeniuk is offline   Reply With Quote
Old 12-28-2014, 04:17 PM   #3
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
Default Re: Pistons
Depends upon how thick the cylinder walls are....if its friction your trying to reduce I think the coatings available take care of that.
If you have a thinwall block (like most fords) that you got carried away with, with the boring bar, you can take some pressure off the major side by offsetting the piston pin to the minor side
and, some say its easier to "rotate" the crank
as with all non standard mods...your mileage may very
Bill Diehl is offline   Reply With Quote
Old 12-29-2014, 08:57 AM   #4
Liked 10,822 Times in 2,250 Posts
Default Re: Pistons
If the pin is offset, would it cause the piston rock and break ring seal due pivot point placement?
Old 12-29-2014, 10:47 PM   #5
Jim Hanig
Default Re: Pistons
Well I am not sure about that Larry some pretty well known engine guys say to run them
Old 12-29-2014, 11:34 PM   #6
FED 387
Liked 333 Times in 180 Posts
Default Re: Pistons
Offset pistons-----small amount of power there--- because of less power need to overcome rod load and easier crank rotation--- it makes engine RPM quicker---FED 387
Old 12-30-2014, 09:37 AM   #7
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: Pistons
Piston rock is actually worse with centered pins.
Old 12-30-2014, 10:57 AM   #8
SSDiv6
Liked 1,604 Times in 583 Posts
Default Re: Pistons
Dwight is correct.
Piston offset reduces friction and cylinder wall loading; it also improves geometry.
F1 and NASCAR has been doing it and also using guided pistons.
Would not be surprised if Pro Stock is doing the same, especially with the use of short deck blocks.
Old 12-30-2014, 02:22 PM   #9
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Pistons
Depends on which way the offset is. Factory offset is to quiet piston noise.
Old 12-31-2014, 09:28 PM   #10
Default Re: Pistons
Is the piston balanced in the center or on the center line of the off set pin placement? Just wondering about inertia.
