Old 12-21-2014, 07:28 PM   #1
rod
Liked 20 Times in 15 Posts
Default header collector ?
bench racin' ?. 4 primary pipes come down to the collector. where does the collector actually start? at the transition where the 4 pipes merge into the true round secondary pipe or where the true round pipe actually starts?
in the former there would only be 2 parts, [1] the primary pipes and [2] the combo merge area and the true round pipe as one unit [as most collectors are formed]
in the later there would be 3 parts to the total header, [1] 4 primary pipes, [2] the merge/ transition area and [3] the true round secondary pipe.
thoughts?
thanks Rod in AZ [and yes it is cold here also]
rod is offline   Reply With Quote
Old 12-22-2014, 05:01 PM   #2
NHRA 303
NHRA 303's Avatar
Default Re: header collector ?
I found this giuys video pretty interesting in showing how the collector actually scavenges. Hpoe this helps. Steve
Header Collector Science
Steve Tucholsky
NHRA 303 is offline   Reply With Quote
Old 12-22-2014, 08:29 PM   #3
Liked 1,865 Times in 422 Posts
The guy you want to talk to is Larry Meaux, the guy who wrote the PipeMax software. Larry has a lot of valuable information on headers.
