Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 12-11-2014, 11:05 PM   #11
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: Shop Lights
Originally Posted by Painter View Post
A lot depends on how high your ceiling and how much electricity you have. With high ceilings you can go with the quartz lites you see in warehouses and gyms. Some of them also have a wider area they light. They also will work on multiple voltage. The higher the voltage you hook the lights up to the lower your monthly cost. For the fluorescent light definitely get the T5 or T8. I like the 8 foot fixtures that take 4-4 foot bulbs. I have been told they are going to quit making 8 foot lamps. Skylights also help and provide the best kind of light- free.
Some Metal Halide lights have 120V-480V multi tap transformers, I sell them in my store, they draw the same wattage regardless of which voltage you run them on.
Paul Precht is online now   Reply With Quote
Old 12-12-2014, 06:52 PM   #12
voltdr
Liked 100 Times in 51 Posts
To clarify. The H.I.D. lights put out the same wattage but require more amperage to operate the lower the operating voltage. Amperage is what spins the meter....
Dan
voltdr is offline   Reply With Quote
Old 12-15-2014, 01:18 AM   #13
Paul Precht
Dan
Amperage times voltage =====Wattage Wattage is what spins the meter not amperage, which is why your electric bill is read in KW not KA. 120V x 10A = 1200W 240V x 5A= 1200W 480V x 2.5A=1200W.
Old 12-15-2014, 01:51 PM   #14
Mike Pearson
Mike Pearson's Avatar
Liked 1,944 Times in 585 Posts
That is Ohms law. Watts/volts =amps
Mike Pearson 2485 SS
Old 12-15-2014, 02:01 PM   #15
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I thought Ohms is what you did when you crossed your legs and closed your eyes.
Rich Taylor
I/SA - 321
Old 01-29-2015, 10:58 AM   #16
Signman
Liked 269 Times in 99 Posts
For High Output cold weather lamps and ballasts make friends with your local sign shop that specializes in illuminated signs. If they have a good relationship with their sign materials supplier the cost is much less than electrical supply house.
There are also LED lighting systems used in signs that put out more white light than you can imagine, if you like to build your own stuff.
Old 01-31-2015, 02:05 PM   #17
Times 2 on that.
They may even have some fixtures that are practically scrap to them.
Look for the HO T12 rectangular pin lamps, at a minimum.
Old 01-31-2015, 09:52 PM   #18
mopacltd
Liked 124 Times in 44 Posts
I use the T5
mopacltd is offline   Reply With Quote
Old 02-01-2015, 04:08 PM   #19
CMcAllister
Liked 920 Times in 259 Posts
We spent a lot of time and probably too much money on this when we built our shop, but the results were great and I wouldn't change a thing.
40' x 52' shop with 96 4' T8s. 24 8' fixtures with 4 4' bulbs each. White ceilings and walls. After not finding anything to suit us at the big box stores, we spec'd these fixtures from an online lighting and design site. Our electrical guy ordered them at his supplier. The shades have perforations to get a percentage of the light on the ceiling and dispersed to help eliminate dark spots. We have them switched so that we can turn on as much as we need, where we need it. The front and rear rows are shaded toward the front and rear walls and the ends of the rows are near the side walls. Lighting on the benches and areas at the walls is excellent.
Old 02-27-2015, 03:36 PM   #20
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
I constantly get fliers from Harbor Freight with coupons for these little flashlights, FREE! ( http://www.harborfreight.com/27-led-...ght-67227.html ) So I go in and redeem the the coupon... I think when I get to a couple hundred units, I will put them up in my "race car bay", for lighting.... It will be a pain in the *** to turn them all on and off, but WTF? They were free....... All this cold N. Illinois weather, gives me way to much time to think about this stuff...... ;-)
