Liked 54 Times in 27 Posts
Dexter has a list of acceptable greases in their instruction manual which you can download from their website. Don't mix greases of different base stocks as they might not be compatible. As above, too much grease doesn't help. Loose bearings don't help--preload per mfg. recommendations. If the seals are good, there is no reason to keep adding grease.
