#11 |
Purple at Bandimere is $9 a gallon.
Lane Weber It`s Not What You Drive That Wins....It`s How You Drive It |
#12 |
Liked 20 Times in 9 Posts
The official race fuel payed there contingency today for my class win at the pacific SportsNational I got a email from them a couple of weeks ago wanting the tax form and now I am payed,now I just need my manufacture to do the right thing. Good Job Sunoco
7015 E/SA Sooner Storm |
#13 |
what is the same as c-11 for sunoco
#14 |
Liked 1,943 Times in 584 Posts
Mickey I don't think they have as many different grades of fuel that VP has. Purple or Blue are the two closest to what we use in Stock/Super Stock. I have used the Blue fuel and it ran the same as VP c-12. I always had problems at fuel check with the color or some other issue that the fuel check guys did not like the Sunoco so I went back to VP. Now that Sunoco is the official fuel of NHRA they might not give as much hassle at fuel check.
Mike Pearson 2485 SS |
#15 |
Liked 263 Times in 68 Posts
I Have used Sunocco Purple for years in my Max Wedge with 11 to 1 compression and never had it fail. I get a barrell delivered to my house when I need it.
John Dinkel 3295 STK |
#16 |
Liked 354 Times in 120 Posts
Right now Sunoco has no replacement for C11, from what I have heard comp pro stock and prostock MC will have to run Sunoco and late season testing has not been good. Will know after PRI if VP will have there own contingency out side of NHRA. Tom
Tom Meyer 5240 SS Stock ??? |
#17 |
Liked 333 Times in 180 Posts
my understanding is Comp can run either VP or Sunoco fuels---Pro Stock Car & Pro Stock Motorcycle must run Sunoco fuel --- Sunoco fuels are mandatory only in those 2 classes--- that's unless things have changed --
as far s C-11 go to the website smithtex.com they break down many popular racing gasolines as to their characteristics so you might be able to clarify what is C-11 in the Sunoco line up=== otherwise I would contact Sunoco ask them what is their equivalent to C-11 FED387 |
#18 |
Hi Lane,
Another reason I'm glad I moved to metro Phoenix....Purple at the Love's Gas Station, across I-10 from Wild Horse Pass Motorsports Park, is $7.49 a gallon, and I've been using it since I found out the gas station sold it...at the pump no less!!!! ![]()
Gary Hampton '86 Z24,173 V6 CF/S #5824 (#78 in 2021) |
#19 |
Liked 693 Times in 205 Posts
All stock/superstock can still use VP, no reason to be in a hurry to switch.
#20 |
Here is the spec sheet on Vp X16 and Sunoco max
(Typical Values) Specific Gravity: .710 @ 60°F Lead: Yes Color: Red Motor Octane: 114 R+M/2: 116 Research Octane: 118 Reid Vapor Pressure: 6 psi Oxygen Content = None Technical Details Color Red Octane (R+M)/2 116 Research Octane 118 Motor Octane 114 Specific Gravity 0.712 Weight (lbs/gallon) 5.9 Reid Vapor Pressure 5.3 10% Evaporation 177 50% Evaporation 214 90% Evaporation 227 Stoichiometric Air/Fuel Ratio 15.2 Oxygen (weight%) 0 Ethanol (volume%) 0 HC Ratio 2.16 Lower Heating Value (Btu/Gallon) 111500 Lower Heating Value (Btu/Pound) 18900 Dielectric Constant -0.8 Leaded Yes Applications Oxidation Stability (min.) 1440+ Distillation:. 10% evap @ 155.7°F 50% evap @ 219.4°F 90% evap @ 254.3°F E.P @ 384.0°F Availability: Sealed Drums
