Old 11-24-2014, 10:44 PM   #1
Doug McCue
Liked 13 Times in 2 Posts
Default Re: How many 9 second 396/375 alum head A/S A/SA
Originally Posted by Pedigo Perf View Post
I'm Tracy and I have Dyno'd Wikle's engines and been involved to some extent to tuning them, including the one in my Chevelle. You seem to imply that Wikle builds bogus engines and I take exception to that. I can assure you that DeFrank and myself requested and received legal weight components. I have seen them and handled them and installed them, and you have not. You can pay to see them at any race you like and I will gladly make a side bet with you. Let me know when you are ready.
At Indy the motor in the car was rejected by NHRA (ask Keith Lynch) this situation is why I am asking NHRA to re evaluate the 402 / 375 in a 1970 camaro. Perhaps it was not legal at that time and now the combo should be re evaluated and returned to the proper hp hp rating
Doug McCue is offline   Reply With Quote
Old 11-24-2014, 11:00 PM   #2
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
Was that last year?.....no wait, eight years ago... or more? Wikle isn't responsible for Keith's decisions either. If he machines a block for someone and they build the engine it is their baby. Darrel knows how to build a good engine that will pass all aspects of tech inspection. It takes a bit more time and money and maybe not everybody has sour grapes because someone went to the extra effort to go a little faster.
Pedigo Perf is offline   Reply With Quote
Old 11-24-2014, 11:06 PM   #3
Doug McCue
You are right the motor NHRA looked at was Keith's fault. So bring the hp factor back to where is was before he killed the combo
Old 11-24-2014, 11:18 PM   #4
Pedigo Perf
I also have a 70 Camaro and I would be right with you on that request but fat chance would be my guess based on the other '70 402's out there. Look at Ken Keir, and that isn't a Wikle engine either.
Old 11-24-2014, 11:37 PM   #5
Doug McCue
the Hp assigned is wrong the camaro has to much nose weight
Old 11-25-2014, 12:03 AM   #6
Tom Moock
Liked 10 Times in 6 Posts
Doug, maybe you should put a stick in your car, because they never came with a automatic transmission from the factory. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 11-25-2014, 12:30 AM   #7
spike1
Liked 53 Times in 16 Posts
Just for the record....the motor torn down at the Indy Nationals was a 1969 375/396 in a 1969 Camaro(not a 1970 402). Everything was found to be legal except for the piston weight, which was 28 grams light. At the end of that season NHRA changed the rule to a piston/rod assembly weight, which would have made the aforementioned engine legal.
spike1 is offline   Reply With Quote
Old 11-26-2014, 03:48 PM   #8
Jim Hanig
Liked 99 Times in 49 Posts
I believe your wrong Tom
Old 11-26-2014, 03:42 PM   #9
Jim Hanig
What? nose weight? I had one of the first 70 Camaros in C it was a 50/50 car. You need a better reason than that.
