Old 11-15-2014, 07:26 PM   #1
MANSRACING
Liked 10 Times in 4 Posts
Default Comp/Super Stock Engine Parts
SBC CNC Bowtie Block: 4.030 Bore, 55mm babbit cam bearings, 4-bolt billet caps, Jesel Key-lifter bushings, all machine work done by Weston Machine, Fresh hone $2,500 SOLD
Bryant Crankshaft: 2.980" Stroke, Honda rod journals, 283 Main journals, MINT condition $1,600
Bullet Cam: 55mm, record setting SS/CS camshaft $250
Pistons, Rods, Pins: BME 4.029 Bore, Rebco Lightened, .7mm ring grooves. GRP Aluminum 6.00" Long, Honda journal, .927 Pin, PPP Casidium coated Titanium wrist Pins .927" diameter x 2.484" Long $500
Calico Coated Bearings: 350 Block journal to 283 crank journal p/n MS1110H $150
Package deal for everything ABOVE to build SS/CS legal shortblock:. $4,600.00
Jesel Keyway Lifters: .937" diameter, .850" diameter wheel, all +.150" Offset $500 SOLD
Dart Iron SBC Castings: SS/CS Approved, brand new in the box set of heads ready for porting. Special ordered with Ductile Iron Exhaust seats, and 5/16" guides $800 for the pair
BRE 750cfm SS/BS-CS Legal 4150 Holley Carb $750
Richmond 9" Ford Gear Sets, Small Pinion on each:
6.20 Pro Gear $100 SOLD
6.33 NEW $150
6.50 Pro, 2 Runs $100 SOLD
See RacingJunk Ad #182325386 for photos
Call Randy @ 612.306.5387 with any questions
Last edited by MANSRACING; 12-09-2014 at 07:10 PM. Reason: sold some parts,entered wrong info
MANSRACING is offline   Reply With Quote
Old 11-16-2014, 11:10 PM   #2
tallison55
Default Re: Comp/Super Stock Engine Parts
Randy,
Interested in your block and parts call me in the morning .
Thanks ,Terry Allison 724 462 6444
tallison55 is offline   Reply With Quote
