#11 |
Liked 485 Times in 160 Posts
#12 |
Liked 370 Times in 101 Posts
Only breakage on mine was a ring & pinion.
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
#13 |
Liked 33 Times in 16 Posts
Well, here we go...
![]() I bought the '90 model this morning from a nice young gal named Shelley...I'm sure she had her fun with it over the years. It was about what I expected to find...pretty much intact with no real rust issues. I still have not dismissed the '89 model and might travel to look at it if I ever get in contact with the seller. Up on the lift I see no glaring defects other than it had taken a hit to the lower portion of the radiator support at some time in it's life...probably from a tall curb from the looks of it. ![]() ![]() ![]() ![]() Interior is decent... ![]() ![]() Top and body are good, but it will need paint. ![]() ![]() ![]() That spoiler must go lol!
Rich Taylor I/SA - 321 Last edited by HandOverFist; 10-19-2014 at 08:58 PM. |
#14 |
Liked 237 Times in 126 Posts
Very subtle looking car. Quite a jump from your Camaro. Welcome to the Dark Side...
What drag racing needs is cars in the lanes. And the more badges and body styles the better. Dale |
#15 |
Whichever car I end up with I will begin with the roll bar/subframe connectors and work my way down to suspension/driveline upgrades. I will try to garner the best info I can get on the best bang for the buck upgrades given the power levels expected. Being O/SA and the index at 13.15 with an automatic it should not be too harsh on parts...I hope.
Rich Taylor I/SA - 321 |
#16 |
Liked 19 Times in 12 Posts
This will be a fun build to watch. Subscribing to this thread.
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
#17 |
Way WOW !!! A virgin Mustang, still has the OE air box and the distributor cap rubber boot. Nice score !! Welcome to O/SA.................
#18 |
I'll be needing you guys to guide me along on this one.
#19 |
Here's some sub frame connectors to look at, My 68 has Total Control/ChassisWorks connectors but they don't make them for the newer cars.
http://www.maximummotorsports.com/MM-Full-Length-Subframe-Connectors-1979-04-bare-P580.aspx Dale |
#20 |
Thanks Dale - Not sure how the weight falls on these cars when gutted...class minimum will be 3300 pounds. Don't know the pros or cons of a moly vs mild steel roll bar in this instance...not wanting to spend money on parts that don't make a difference if you know what I mean. This entire endeavor will be based on the best bang for the buck if feasible. I would also like to find out if it is possible to claim this car as a '89 and what would be needed to do so...would drop weight to 3225 and hp factor to 215.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 10-19-2014 at 10:12 PM. |
