Old 10-12-2014, 06:50 AM   #1
Paul Ceasrine
Liked 10 Times in 10 Posts
Default Re: Early 1970s Raceway News Scans
1973 NHRA Super Stock and Stock Class Weight Factors
Cook and Leong
1971 Dodge Charger R/T ~ 426 Hemi ~ Class 'B/SA'
In 1973,
The NHRA had re-factored the 1971 426/425 HP {Hydraulic Camshaft} to {450 HP}
#3839 lbs. ~ 450 HP = 8.53 Wt/HP
Now that was one nice weight break for 1973.
For Stock Class, any tires {DOT approved} that could fit within the Rear Fenderwell was permitted. This Charger R/T had 12" Wide Tires.
In 1973 Stock Class, you had run thru a full exhaust system {No Headers}.
Rumor has it, that this 1971 Dodge Charger R/T was 'chemically engineered' at the factory by Chrysler.
Old 10-12-2014, 12:14 PM   #2
Dennis P Chapman
Liked 53 Times in 25 Posts
Artie is on here sometimes maybe he can give so info on the charger.
Dennis P Chapman 1904 STK
Old 10-12-2014, 01:59 PM   #3
Paul Ceasrine
I remember being behind that 1971 Charger R/T '426 Hemi' in the Staging Lanes at Englishtown.
I was running my 1969 440 'Cuda in B/SA as well.
That Charger had 'Mother Monster' rear tires, which were nearly a
Foot wide.
Old 10-13-2014, 11:18 PM   #4
mopar68
mopar68's Avatar
Liked 44 Times in 27 Posts
Old 10-13-2014, 11:22 PM   #5
mopar68
mopar68's Avatar
Foot wide.
Definitely some wide muthas.
Pete
Old 10-14-2014, 06:47 AM   #6
Paul Ceasrine
Pete,
This should be from 1974
In the above photo, that is Charlie Castaldo in his 1974 Pro/Stock Duster.
B/SA National Records
* 11.76 ................ Held by a 1970 Plymouth Superbird '426 Hemi'
* 117.44 MPH ..... Held by a 1970 Plymouth Cuda 440-6 'Six-Barrel'
Old 10-14-2014, 01:09 PM   #7
mopar68
mopar68's Avatar
Pete,
This should be from 1975
In the above photo, that is Charlie Castaldo in his Pro/Stock Duster.
1975
a) Even though I no longer has the RN issues, it has to be from 1974 simply because I didn't have any 1975 Raceway News issues.
b) The above Plymouth Hemi Superbird record holder was Lou LaFreda.
Regards,
Pete
Old 10-14-2014, 01:33 PM   #8
Paul Ceasrine
Pete,
You are correct.
1974
In Stock Class, you couldn't run Slicks, but you were allowed Monster Mother Tires, as long as they fit within the Rear Fenderwell.
I believe Ray Cook and Art Leong had N50- x 15's on the 1971 Charger R/T.
I had Concorde G60 x 14's on my green 69' 440 Cuda for 1974.
Thankfully, we were allowed Headers in 1974, but still had to retain
the full exhaust system w/tail pipes.
I ran against them on a 'Cold *** Day', and I couldn't hook up, and broke loose sideways coming off the line.
I nearly T-Boned the Charger.
