Old 10-01-2014, 05:13 PM   #1
RJ Sledge
Liked 291 Times in 92 Posts
Default Cobra Jet 352 Stock Eliminator
Thinking of changing Class and need to sell our 352 CJ motor/(or heads) to purchase new parts.
Machine work and heads were done by Jim Kuntz @ Kuntz & Co., SVO long cylinder 4 bolt main Block, 4.100 bore( 4.125 with no problem), Diamond pistons w/Total Seal ring package, Harland Sharpe shaft rocker system, Comp beehive springs and hardware, Ferrera lightweight intake valves and Ferrera exhaust valves, Bullet roller camshaft with Crower Hipo roller lifters, adjustable Melling oil pump, Callies rods and Crank, Trend push rods, MSD Billet Dist , Ford Racing oil pan, correct Victor/Ford intake and throttle body and spacer, etc., etc..
35 easy passes on motor, never a problem.
Car has been 10.20's @ in bracket trim
Also have complete body kit for a 2010 CJ ( HP white) front and rear facia, fiberglass hood with flush hood latches, tail lites complete and headlites complete, upper and lower grille and top grille surround and all brackets and supports. We just changed ours over to a 2013-2014 CJ.
Would do some trading for the right pieces????
Please private mail me if interested.
Thanks RJ
RJ Sledge is offline   Reply With Quote
