NHRA Disqualifies Two Competitors during the Chevrolet Performance U.S. Nationals.
#1 - supercharger pulley did not meet specs. #2 - false battery installed.
Troy "City Dog" Pourciau |
Liked 243 Times in 32 Posts
I spoke to the gentlemen with the false battery. It was a borrowed ride and he
was unaware. He wanted to fix it but NHRA wouldn't let him. Last edited by robzneed4speed; 09-05-2014 at 03:42 PM. |
Liked 24 Times in 1 Post
I had a fake battery in tech a couple years ago they found and we didn't even know it was a fake battery...Bo actually argued with the tech guy about it until we unscrewed it and lifted it up. There were quite a few of us that had them and it was more annoying than anything. I don't understand why they care so much about that. It is still stock appearing. I can't believe they would throw someone out for that.
Liked 26 Times in 11 Posts
I have it from a good source that the supercharger pulley was larger than the specification.
There is no plus or minus tolerance on the pulley spec's. unlike crank stroke. The rule needs to be clarified before a competitor gets pitched. Not a good call by the NHRA. See you at the races, Wayne Kerr Last edited by Wayne Kerr; 09-05-2014 at 03:52 PM. Reason: grammatical fubar |
#5 | |
Ed Wright 4156 SS/JA |
#6 | |
Liked 3,205 Times in 977 Posts
Liked 115 Times in 5 Posts
I believe the pulley was too large and there is a spec on the pulley diameter.
Evan Smith 1798 STK |
Liked 248 Times in 89 Posts
Classracerinfo.com shows a spec of 3.5" upper and 8" lower on the pulleys for the 2013 CJ (2014 won't load). If you are using OEM pulleys and wanted to argue that the OEM manufacturing tolerances are unknown, how much deviation from the posted specs should you be allowed? Up to 1%? 5%? 10%? At what point does it become an unfair advantage?
Does anyone know how far off spec the pulley actually was? |
#9 | |
That all it says Mike.
#10 | |
Liked 6 Times in 4 Posts
