Old 08-21-2014, 08:52 AM   #1
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
Default Re: Indy stock low qualifier
Originally Posted by Charley Downing View Post
Heading back to the farm with a completed six cylinder short block for the truck. Thanks CP for getting pistons out to us in less then a week. Cylinder heads should be done Friday and plan to test sunday a Milan. Indy should be fun.
Charlie,
I'll give you tip on the V-8 /V-6 swap, when you look at frame mounts looks like you could slide them back and bolt 4.3 right in,but it won't, but is simple to fix. take brackets that lower motor mounts go on and slot mounting holes where lower motor mount goes and slot the holes to where you have about 1 1/2 - 2'' slots so you can slide lower mount down,I made the slots on bridgeport style mill, if don't have mill can drill row of holes close together then use carbide burr cut rest of the way, you probaly have to drill hole where frame mount bolts to crossmember also.
You may have known this but if not may save you a hour or two.
Is 350 1 pc, main? most 4.3 are 1 pc rear main,they use different flywheel than 2 pc. rear main
Mike Taylor 3601
Old 08-28-2014, 11:33 AM   #2
Greg Hill
Liked 279 Times in 68 Posts
Hee Heee! LMAO
Greg Hill 4171 STK
Old 08-28-2014, 01:33 PM   #3
FED 387
Liked 333 Times in 180 Posts
almost got a 12.999 out of it----WOW!!!!
Old 08-28-2014, 01:51 PM   #4
Joseph Teuton
Joseph Teuton's Avatar
Congrats Mr. Larry and Mrs. Pasty!! Go Team Hill.....!!!
JOSEPH TEUTON
4044 STK,SS,
Joseph Teuton is offline   Reply With Quote
Old 08-28-2014, 05:52 PM   #5
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
Congrats to the Hills on that awesome 2.21 under run.
Well done.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 08-28-2014, 10:43 PM   #6
farmco r/sa
Liked 147 Times in 54 Posts
Thumbs up Re: Indy stock low qualifier
Well done.
Truly amazing !! more than 1 second
under the "AHFS" auto trigger of -1.20
under .......congrats !
Randy Hyman. Lakewood co. stk 5394
P/SA
farmco r/sa is offline   Reply With Quote
