Old 07-28-2014, 02:02 AM   #1
Pat Cook
Default 90 Ford T-Bird Super Coupe
I have an opportunity to buy a 90 Ford T-Bird with supercharged 3.8 for cheap, like junk yard price, it runs but has a leaking water pump. Car fits into N or O but it is heavy like 3795 lbs in N or 3920 lbs in O.
They are fun to drive, feel pretty quick.
Has a 8.8 axle, but a IRS rear suspension, like a Corvette.
302 C4 will bolt to the engine.
What do y'all think?
Mark, Billy?
67 Ford Fairlane
F/SA
749
Pat Cook is offline   Reply With Quote
Old 07-28-2014, 08:27 AM   #2
Billy Nees
Default Re: 90 Ford T-Bird Super Coupe
I'd bring it home and play with it! If it doesn't work out, bring it back to the yard and get scrap for it. I don't know anybody who has played with one but it DOES have a blower on it. Gary Simpers races a 5.0 T-Bird in Stock so the IRS can be made to work. As I recall, they had some pretty serious head gasket problems and unlike a turbo car, you can't just crank up the boost(you have to use stock pulleys, not Stock pulleys) but I think it would be fun to play with. I wouldn't get serious with it to start. Just get it to a track and see what it does. If it shows some potential(and doesn't hurt itself) throw some Stocker tricks at it and see how it reacts. It may be a V6 and it may have a huffer on it and it may be a FFFFord but the pistons still go up and down under the valve covers and it doesn't know what it is.
Billy Nees 1188 STK, SS
Old 07-28-2014, 10:32 AM   #3
Bill Harris
Liked 26 Times in 13 Posts
I think that is a Fox body platform and if so the IRS just bolts into attachment points used for the regular live axle version of the chassis. Since Corvettes are able to swap out their IRS for a live axle in stock it seems reasonable that you could do the same. It is very easy to get a fox chassis 8.8 rear housing, you will trip over several at almost any junkyard, and just bolt it in. The live axle is quite a bit lighter than the IRS and there are suspension parts galore for that configuration too.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 07-28-2014, 11:34 AM   #4
Pat Cook
Yeah, I'm going to buy it. Haul it over to Vegas and abuse it. If it doesn't squirt the head gasket's....If it show's signs of anything, I think Cometic will build a set of gaskets for it.
The main thing is the price is right.
67 Ford Fairlane
F/SA
749
Old 07-28-2014, 06:21 PM   #5
Fireofficer5
Liked 33 Times in 20 Posts
Its not a Fox body.
Its a MN-12.
Its a heavy car.
Go to sccoa.com for good information.
Fireofficer5 is offline   Reply With Quote
Old 07-28-2014, 07:01 PM   #6
rick lester
Liked 4 Times in 1 Post
Hey Pat, let me know when you go to Vegas to play. Text 352-942-8613
rick lester is offline   Reply With Quote
Old 07-28-2014, 08:31 PM   #7
A friend of mine worked for Ford when those first came into the market. If I remember correctly there was a pretty common issue of broken crankshafts early on.
Might be a foggy memory.
Maybe this was the issue????? It's been a few years.
http://www.35thatr.org/Tips/HarmonicDamperBreak.htm
Old 07-28-2014, 09:00 PM   #8
Pat, It ought to run the index anyway with the right converter and gearing.
Beyond that, I don't know.
That thing has a nice looking cylinder head and a decent cam, but quite a bit of weight for a small motor.
Maybe a candidate for a hp reduction.
Let me know if I can help you with anything.
Old 07-28-2014, 09:10 PM   #9
rawhide
Liked 7 Times in 5 Posts
the early 1989 models had a cast iron crank but on 1-30-89 they changed them to forged steel. there must have been a problem because a car company will not spend a dollar they don't have to.
regards, Roland
rawhide is offline   Reply With Quote
Old 07-28-2014, 10:37 PM   #10
regards, Roland
Yep.
Thanks for the clairification. I remembered it was early.
At least part of the memory is still there.
