Liked 2,359 Times in 557 Posts
Should they be banned in Stock Eliminator?
as long as they are solely hooked to a data logger for the purpose of measuring converter or clutch slip, no. If its being converted to MPH and displayed or its hooked to an ignition box, yes.
Chad Rhodes 2113 I/SA |
Liked 460 Times in 91 Posts
Maybe they should check on this...............
Bob Bender 144 O/SA 2010-2012 National Record Holder |
I was told this weekend that some Cobra Jet cars come with traction control from the factory and therefore it is legal.
Is that true? (I have no clue... flame suit on...) ![]()
Ross Gregory 5133 Stock,Super Stock 53 Top Dragster |
Liked 10,836 Times in 2,252 Posts
I'm always envious of those high hp. cars that only slip a radial tire a half of a turn at a hot and slick track.
Liked 275 Times in 76 Posts
That's a problem if the DS speed is not separate from the engine management system. The new cars probably have all sensors being monitored, so it would be very easy to manipulate the engine output if the DS speed did not match the front tire speed. Data acquisition and engine management should be separate.
Sean
Liked 26 Times in 11 Posts
Good afternoon Guys,
The production Cobra Jet's do not have traction control. Could they? yes, but not any easier than putting a Davis system on your carbureted car. Or running a delay box. See you at the races, Wayne Kerr |
Liked 79 Times in 22 Posts
Shelby Mustangs come with traction control, Cobra Jet Mustangs do not.
I would add wheel sensors to the discussion.
