Liked 1,832 Times in 415 Posts
With the exhaust huffing smoke like that, you almost certainly have a ring seal problem. Doesn't look like valve stem seals at all. Oil on the plugs and the bottom of the carburetor is a bad sign as well, the guides would have to be so loose that the valves wouldn't seal on the seats. You need to run a compression test and a leak down test.
Alan Roehrich 212A G/S |
Liked 112 Times in 31 Posts
Second ring in upside-down?
Jerry |
Total Seal gapless top ring???
Liked 293 Times in 65 Posts
Tim, yes those are the ones. I filed to .028 as per Keith's instructions.
Liked 20 Times in 9 Posts
You made need to shim the top groove with that set up from Keith.
7015 E/SA Sooner Storm |
Liked 288 Times in 90 Posts
Paul
I had a problem like that and it turned out to be the wrong size oil ring expander and rail set. They felt really loose when I put the motor together, and said to myself, if it seals up it will fly. Well, it was just as you described, pulled the motor down and replaced with a bigger expander and rail set and the car flew. If you are using Total Seal look at the label on the oil ring package and see what size is printed on it. They had sent a4.040 expander package while the top and second rings were for a finished bore size of 4.100. Believe I wound up with a 4.060 oil package set . I always use a digital fish scale and pull a piston (with the oil ring package installed) through the cylinders to check for how much drag. I shoot for around 8 to 10 lbs. Its a little tricky, put try and keep it moving smoothly in the cylinder. Good Luck We learn a whole lot more from our mistakes than we do from our successes. Hey, how long is your camper footprint? Look like it fits perfect without overhang. RJ |
Liked 1,937 Times in 582 Posts
I had some real bad problems with the gapless rings. After one run absolutely no compression. The engine would not start. Checked With leak down and 90% in all cylinders. Every ring was seized into the ring land both top and 2nd. I spoke to Total Seal and Patterson and no one could give me a good reason for the problem. I followed their instructions to the letter and used a premium break in oil. Definitely a ring problem.
Mike Pearson 2485 SS |
Paul,
I'm sure there is smart engine builders out there that can make those gapless top rings work in a stocker set up, I tried and could not but I only do my own junk so take it for what its worth.... If it was me, I would pull the engine apart, scrub the cylinders with dawn dishsoap and brush them, remove the gapless top ring and throw them as far as you can, then find them and burry them so you don't try them again. Install some standard 5/64 rings and have fun. They do seal awesome on compression, not sure what happens on the down stroke that makes them drink oil. I used two quarts in 10 dyno pulls and gave up. I heard of guys using a PCV set up to assist but with my tune port setup, it pulled oil out of the valve covers rapidly. Good luck! Tim |
The plot thickens...
Today I installed new metal-clad Viton valve seals. Fired it up, and no smoke! As a side note, I originally had 6 qts of 30 wt. Valvoline along with a pint of Comp Cams break-in lube in the pan. Today I put in 5 qts of the Brad Penn since the cam was broken in. Anyway, all was well until about 2 minutes in when the oil pressure gauge dropped to around 20 lbs. I immediately shut it off. Waited a few minutes and cranked it back up...had around 60 psi for a minute or so, then it dropped again. I'm thinking all these issues are related to filling the valve covers with oil. For some reason, there's either too much getting up there or not enough coming back down. Either way, it ain't good! I don't get it...same block and heads from last year. Different oil pump (Schumann low-volume), different head gaskets (FelPro MLS), pushrods, lifters, and roller rockers. Is there a plug that could've gotten left out? Could the lifters be allowing too much oil up top? By the way, I noticed the other day that the pressure on startup was 72 psi but after a couple minutes it started to "flutter" down to 55 or so. I have the 60-65 psi spring in the Schumann pump. Last edited by Paul Merolla; 06-04-2014 at 11:56 PM. |
