#11 |
Liked 27 Times in 14 Posts
When it comes to coil springs, front and rear, we stock and sell products that already work, and are not super expensive. I dont want to speculate how much R&D Dad has done over the last 40 some odd years with nothing more than stock replacement components.
I would say unless you are going to be more specialized like the Moroso or Eibach, it would not really be worth your time with the R&D. Just my opinion of course. AD> |
#12 |
Liked 33 Times in 16 Posts
Moroso front springs are all we have ever used...no idea where to start with the Santuff's. We have always had to cut at least one coil on the Moroso's to get a decent ride height and to prevent bowing of the spring. With that set there is always a probability of one or both springs collapsing...this usually happens soon after install if it is going to happen at all. The latest set has 1-1/2 coils cut...sagging a little now but still acceptable. About 1690 pounds on the front of this car w/driver and small block.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 05-31-2014 at 01:32 AM. |
#13 |
Liked 1,436 Times in 299 Posts
It used to be that front springs were a one time purchase without much thought given to replacement. Moroso was the only choice forever. Observant racers have tried some alternatives that were much better than the typical spring that required cutting and often ended up too stiff. Different cars have different needs. While some cars have off of the shelf items that work, there are many cars out there that would benefit from a custom spring.
We tried different springs and found a set that was awesome for our car, but difficult to fit yes. I also don't expect them to last forever. Fresh springs of the correct size spring rate, etc have a place in the market. More racers are figuring this out, but not all racers have an alternative. If we can order custom springs at a reasonable cost, I think there will be a growing market. It will require testing. Some people want someone else to figure their cars out for them on the internet and never test. Then they complain when others are faster..... ![]()
James Schaechter 3163 STK |
#14 |
Guest
Posts: n/a
Matt, check your messages please.
#15 |
#16 |
Liked 275 Times in 76 Posts
Matt,
I would be interested in springs. The Moroso springs are not ideal in my opinion. This is from my experience with Fox body Mustangs. Thanks for looking at a viable marketplace for your products. Sean
#17 |
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
Matt
We sell and use Santhuff shocks and springs. You are welcome to call me and discuss anything you may want to ask in the drag racing world of oem springs for stock and SuperStock My cell is 717-793-6819
Marty Rinehart Jr 1125 SS STK SG SC SST |
