Old 05-19-2014, 10:47 AM   #21
ss wannabee
Liked 7 Times in 7 Posts
Default Re: '69 396 2-barrel
1970 combo is better...
Ed Curtis....
The big wagon was Ray Litty's....Now Bob Bender's...
Thanks! Didn't know that car ended up with Mr. Bender....
(btw....Dad waited another year and bought a new '70 big wagon with the 350/250
and th-350....car is long-gone now....)
ss wannabee is offline   Reply With Quote
Old 05-19-2014, 11:42 AM   #22
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
The 1969 350 used the 441 Heads on both 2v and 4v models.
FWIW the QJet was worth almost a full second over the 2V.
I saw 8 tenths..
Dan
Old 05-19-2014, 10:21 PM   #23
Bench Racer
Liked 99 Times in 21 Posts
Just thinking out of the box, but I would think to find out the true potential of the 2bbl. vs the 4 bbl. 350, different converters and stocker cam profiles would need to be tested. I would think the torque curve and rpm range would be pretty different and most cams and converters are optimized for the higher RPM Q-jet motors. The dirt track guys up north have to run the Rochester 2G's in some classes. Several articles were on the web discussing these engines and the differences from the 4bbl cars and cam profile is a huge factor on the restricted engines. They mostly recommend cams with much less duration than the 4bbl cars run, especially on the exhaust side. Don Jackson
Bench Racer is offline   Reply With Quote
