#1 | |
Liked 5 Times in 2 Posts
Adriel Paradise, Paradise Racing Team Driver/Crew Chief(at least my dad claims me to be) B.S. Mechanical Engineering, University of Arkansas |
I think it's a frickin awesome idea making use of the old D3 heads to compete with the Chevy's and the Mopar's. Off the shelf parts, pretty much straight forward build with lots of D3 manifolds to choose from unless you want to go sheet metal. The Jesel rocker components are still available, some in bulk from various Nascar parts outlet sources; and the cranks, rods, and pistons are no biggy. Put it in front of a 3rd pedal set up and have a blast
#3 | |
No, you cannot just go build an Ebay engine. There is a specification sheet for cylinder head volumes, stroke and rod lengths. Also specific part numbers for the cylinder heads, intake crankshaft and connecting rods.. |
#4 | |
Liked 26 Times in 13 Posts
Bill Harris ex 2172 STK ex 2272 S/S |
Liked 294 Times in 93 Posts
I need a junk, wore out, blown up, damaged D3 head (1) so I can do some R&D on the ports and combustion chamber.
Thanks in advance RJ |
#6 | |
704-662-6982 Bill
#8 | |
And yes I agree just about everything is a spec piece from the block, bore size, stroke, rod length journal, and weight, piston dome, valve size, rocker ratio, port volumes, and camshaft lift. That's the beauty of this deal, everything for the most part is available off the shelf and readily available. No more chasing down old head castings. I never said used Ebay heads would work in this application. This was an assumption on your part. I was referring to some off the shops who still have bare castings laying around and available, as well as Jesel rocker bars, arms, and shafts . All Ford Racing D3 castings are cast with the same part number M-6049-D3. Everyone knows In Stock Eliminator the intake manifold will be what ever piece(s) and part numbers Jesse submits. In SS it's what ever you choose to use. We do have Chris and Jesse to thank for bringing the 352" Sbf and the 428" Sbf to stock and super stock eliminators. And now they have given Ford Racers another bad *** killer bullet. I stand by my above post that this will be a good thing for Ford Racing in the sportsman classes. If I wasn't already chest deep in another class car build, I would be all over this. |
Liked 239 Times in 94 Posts
Originally Posted by Jeff Teuton
I prefer a water car or theft recovery as opposed to a wreck, so I'm sure somewhere down here, there will be a flood. Would that be Levee Cutta? ![]() I'm just surprised about the inch of lift in non-roller Nascar motors. |
