Old 05-07-2014, 11:56 PM   #1
SSDiv6
Default Re: what happened to Jeff Lee
Originally Posted by jmantle View Post
Same rules should apply. Unfortunately over the years a lot of bogus stuff has managed to slip thru, sometimes with the "cooperation" of the factory guys. The problem the AMC guys face is there small numbers, less people making noise.
Group 19 3310 Holley on the Pacer, think that should be legal?
Jim Mantle V/SA 6632
Your are using a poor example of using the 3310 Holley in a Pacer since there was not a 4 barrel engine offered. The 3310 Holley only applies to 4 barrel engines. The use of the 3310 Holley is the same issue as when they allowed the Boss 351 to use the Holley carb in lieu of the Motorcraft OEM carb.
The issue of "making noise" is the fact that NHRA has always been selective of whom they allow to get away with changes to the specs.
