Old 04-17-2014, 05:25 PM   #1
GUMP
Liked 2,354 Times in 554 Posts
Default Re: Has there ever been a 4 cyl. car run in the 11's in Stoc
Originally Posted by LASTNDN View Post
They are relatively heavy....
Lot's of stuff can come out for Stock.
....auto trans would have to go since it is delicate, rear gears are hard to find,...
Both can be replaced with much better parts.
....Worst thing I've had to deal with is the electric throttle (seems to open/close when it wants to) and the granny controls on the engine management system...
This could be fixed with an aftermarket controller. I'm not sure how the direct injection would be dealt with, but I bet it can be figured out.
....Another problem is the interior is very confined, so putting a cage in would require someone smaller than my 6 foot 3, 232 pound frame...helmet sticks out above the windshield now....
It would be tight. Only requires a roll bar. Keep in mind that you would have to run with the top up.
....No doubt, under stock class rules, they could be made to run well, especially putting in a different trans/converter....
I bet that both combinations would do well.
....Big heavy wheels all around, stock are 18x8. I believe smallest front wheel would be a 16 inch due to brake size.....
You would want to install aftermarket brakes.
It wouldn't be cheap to build a Solstice, but I think it would be a cool car to race. I would love to have a four cylinder wheelstander!
Old 04-17-2014, 05:57 PM   #2
Chad Rhodes
If I thought for a minute I could comfortable get in one of those cars I'd build one.
Chad Rhodes 2113 I/SA
Old 04-17-2014, 08:33 PM   #3
Barnstorm
Barnstorm's Avatar
Maybe someone should peek in Chuck Blossom's garage. It doesn't take him long to get bored.
