#15 |
Liked 2,487 Times in 698 Posts
I am afraid probably so...........
Particularly if it is fairly fast ( 1.498 to 1.54 60's ) Jon 's wagon P/SA = 3850 O/SA= 3620 Small Valve Low Po 318 = 230 HP with 380 Lift Mark William's 35 Spline/Axles/Pro Gears In Phoenix this year .....Broke 9 Teeth off Ring Gear Bent 8 3/4 like a pretzel Took an hour to get each axle out with slide hammer with 300 Lb Guy on the end. Your results may vary.
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 04-16-2014 at 10:53 PM. |
