#11 | |
Chad Rhodes 2113 I/SA |
#12 |
Liked 13 Times in 10 Posts
i agree with Billy, broken stator support, did the same thing back in 09 with my 305 k/sa camaro
#13 |
Liked 425 Times in 56 Posts
I have broken 2 stator supports. some are now changing them with a heavier one I believe adapting a turbo 350 one... that's what it sounds like to me
Gary Parker 1617 STK |
#14 | |
The low sprag is the weak spot alright. You need to find out if the lo/rev clutches are on or off with your valve body. If off ,and just the forward clutch on, I'm going with the sprag slipping.. Probably find broken springs and distortion on some kind...
#15 | |
#16 |
Liked 49 Times in 15 Posts
If you have engine breaking in 1st gear, then the clutches are on.
Dean Feiock -- Stock 5002 |
#17 |
Liked 33 Times in 16 Posts
Happened to our 200 yesterday at Bowling Green...
Rich Taylor I/SA - 321 |
#18 | |
If the stator support broke would it damage the converter ?
#19 |
I don't know that answer either. Just to be safe I'm going to let ATI cut it open for a look on ours.
#20 | |
Even if the converter doesn't get damaged, it will be full of debris. Needs to come apart either way.
