Old 04-13-2014, 11:38 AM   #3
Chad Rhodes
Default Re: TH200 issue
Originally Posted by Alan Roehrich View Post
Depending upon the valve body, it could be leaving on the low clutches, or on the low sprag. In manual low, it should be on the clutches, if it has an auto 1-2 shift, and leaves in 2nd, it is leaving on the sprag.
By the way, I was at the machine gun shoot when you called, no way I could have heard you with around 30k rounds per minute going off.
It's an e-shift so it acts like a manual. It would have been on the clutches. Sounds like you had more fun than me yesterday. I'll give you a call this evening.
Chad Rhodes 2113 I/SA
