Liked 2 Times in 2 Posts
I have a 67 Camaro with drum front brakes. I want to know what brand of disc brakes would be a good choice for this particular car.
thanks Corey |
Liked 231 Times in 107 Posts
Lamb
you'll get answers all over the board, and you'll hear good and bad about all. We sell aerospace, wildwood, strange, and the limited applications moser has available. We sell more aerospace than anything. Some people don't like the aerospace, but we don't have a lot of issues with them, and when there has been an issue, they've always taken care of it.
Chad Rhodes 2113 I/SA |
Liked 1,943 Times in 584 Posts
I have aerospace on my car on all 4 corners. They work real good. The install was easy. The only issue was a few of the holes needed the threads chased. Other than that the fit was good. You wont believe the difference in braking with the discs. I think the fronts were a 15 lbs per side weight savings.
Mike Pearson 2485 SS |
#5 | |
I have heard people bad mouth Aerospace. Had them on mine for over six years with no problems. Light, easy to install, don't drag, and stops great. Also have F.J.Smith's manual brake conversion. All works very well.
Not sure what more expensive brakes would do better.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 04-08-2014 at 08:09 AM. |
Liked 693 Times in 205 Posts
Mark Williams
Liked 33 Times in 16 Posts
Aerospace on all four corners of our '67...can stall it to the moon on any surface and it won't move.
Rich Taylor I/SA - 321 |
Liked 127 Times in 49 Posts
Anyone know how to get the Wilwood front discs to quit dragging?
Bobby Lundholm 3516 G/SA |
Bobby - When you fully retracted the pistons and first put the calipers/pads on the rotors did it require any effort? I've found some brake pads have just too much material/thickness when new to allow any clearance.
