Old 04-06-2014, 12:11 PM   #1
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
Default Re: J W Ultra bell installation
Originally Posted by Lyn Smith View Post
thanks for the pics Bob.I was thinking of drilling the holes as a guide line also.
I have done several. Best off to measure back and make a rough cut short of the cut line. Then you can see exactly what you are doing. I used a 4 inch grinder with a cut off wheel to make the final cut. Then cleaned it up with a flapper wheel on the grinder. Take your time and measure twice. Double check to make sure the new bell is perfectly flush with the pump and is not touching the case anywhere. I have had real good luck on my powerglides.
Mike Pearson 2485 SS
