Old 04-03-2014, 02:59 PM   #22
FED 387
Liked 333 Times in 180 Posts
Default Re: Gas or Diesel?
one thing I forgot to mention is are you handy? by this I mean can u do home repairs? --what you have here is basically a rolling home--- as it twists and turns and vibrates its way down the hiway things tend to loosen up-so you're gonna have leaks,rattles, electric that does not want to work etc.- like checking and tightening the plumbing fittings /electric connections /cabinet doors etc... You will need to know basic home maintainence stuff otherwise you're gonna be in the shop @ $100+ per hour fixing stuff---not all the time but periodically you hafta go over those things and just do preventative maintainence to make sure things don't break down--FED 387
