Old 09-27-2007, 01:09 PM   #1
Todd Bailey
Liked 33 Times in 17 Posts
Default Which Spring Perch?
For a 12 bolt rearend:
When running the Calvert Split-Leaf springs, which spring perch is required or preferred? The mono leaf or multi leaf ?
Thanks
Todd Bailey is offline   Reply With Quote
Old 09-27-2007, 05:59 PM   #2
bob gonier
Default Re: Which Spring Perch?
Good question....... I use the "mopar" style perches on mine but I would assume a factory mono leaf perch would be the best bet. I think a multi leaf perch is too deep and would reaquire a shim of sorts. The split mono's are not as tall as the factory multi's but taller than a factory mono.
Make any sense ????
Now I'm confused ????
bob
bob gonier is offline   Reply With Quote
Old 09-27-2007, 06:48 PM   #3
Todd Bailey
Bob,
That is precisely what prompted me to ask this question!!! I would think (which is usually dangerous for me to do) that the mono-leaf perch is too shallow since the split-leaf is basically two leaves stacked upon one another. I e-mailed Calvert Racing but have yet to receive a response.
There is a lot of brain-trust out there so hopefully someone can shed some more light on this.
Anyone?
Old 09-27-2007, 07:31 PM   #4
denny harvey
i just put the calvert split leaf springs on my 67 camaro and i used the universal perches from jegs.they work great and the locating pin [ bolt ] on the leaf springs fit into the locating hole in the perch so everything lined right up...parts and labor was about $100. hope this helps..
denny harvey is offline   Reply With Quote
Old 09-27-2007, 10:49 PM   #5
Adger Smith
Liked 880 Times in 311 Posts
I've always preferred the Blue Gill or Sun Perch. On light tackle they are fun to catch...They are always tasty when pan fried.
Adger Smith (Former SS)
Old 09-27-2007, 11:10 PM   #6
Todd Bailey
Hmmmmm.......I wonder if these are available as well in the Jeg's catalog?.........
Old 09-28-2007, 08:42 PM   #7
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
May not be in the Jegs catalogue, but I bet their travelling chef could cook some up for you if you wear a yellow shirt & hat !
Old 10-01-2007, 02:22 AM   #8
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
Use the Mopar perches and box them in. That will do the job.
Joe Martens AA/Stock 3969
Joe Martens is online now   Reply With Quote
