Old 03-10-2014, 05:13 PM   #131
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: '67 Camaro E/SA redo
Originally Posted by cad View Post
Thanks. I think I need to space out the lower driver side alternator bracket and go with the long water pump crank pulley. I think that is what yours has.
Cad, you might get some ideas from this lash up. Crank pulley is an East Coast #2253.
For what it's worth..... -Al
"That'll never work....."
Old 03-10-2014, 07:52 PM   #132
brent flynn
brent flynn's Avatar
Glad you got it back together...hope Saturday goes well! Im waiting about 3 more weeks before i set my engine/trans in...gonna run the car one last time, with bracket engine, to make sure that ignition is good...Hooked up MSD around Thanksgiving...I cant make APril INdy meet , still need a couple things, and its TAX season..., but i will be there watching... Shooting for Joliet..then maybe Bowling Green in Aug
Old 03-11-2014, 12:42 AM   #133
cad
cad's Avatar
Liked 93 Times in 52 Posts
Thanks Alan....we spaced it out tonite using the long crank pulley and I think it will work.
Clark
Old 03-11-2014, 01:07 AM   #134
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Yes, I was glad it wasnt more serious as well. I'm replacing both u-joints in the driveshaft with Spicer non-drilled units just for peace of mind before it goes back into service. Plans right now are to take the car to Music City Raceway in Hendersonville Saturday afternoon...just a 1/8-mile track, but it generally hooks well and will give a good indication of the car's potential. Once satisfied with the reliability we will head back to Bowling Green.
Rich Taylor
I/SA - 321
Old 03-11-2014, 06:36 AM   #135
brent flynn
Originally Posted by HandOverFist View Post
Yep - If we can muster a 5-under car that is consistent I will have reached my goal for this season. I know it will take more $$$ in the motor to run heads up. Plans are to run all the combo races this year at Beech Bend so I can gain some experience at racing the finish line...my weak point.
How many combo races are they running , this year? You have schedule?
Who knows, i might be able to hit one or 2...Thinking about the August divisional, right before the Nats...
Old 03-11-2014, 07:15 AM   #136
HandOverFist
About 8 I think Brent along with other events... http://www.beechbend.com/dragschedule.htm
Rich Taylor
I/SA - 321
Old 03-11-2014, 07:13 PM   #137
brent flynn
Cool...thanks!
Old 03-12-2014, 12:05 AM   #138
kwm
kwm's Avatar
Liked 4 Times in 3 Posts
Cool...thanks!
Ohio Valley has 7 Combo races & the Doorslammers on the schedule.
Kenny Miracle
P/SA 310
kwm is offline   Reply With Quote
Old 03-15-2014, 11:08 PM   #139
HandOverFist
Finally, some good news to report. Took the car to a local 1/8-mile track this afternoon (Buffalo Valley) just to see if it would go down track without any parts falling off. Although the track runs slightly uphill and the start line was less than ideal we finally caught a glimmer of the cars potential.
The first pass was with the Caltrac links in the upper holes and the carb a little lean.
Second pass with the links still in the upper holes and added richer metering rods.
Third pass we put the links in the bottom holes. We made four more laps down the track, but it was getting ugly by then with tire spin on the launch so we called it done for the day. I figure the next trip to Bowling Green will result in low 1.40's 60' times from being on a prepped surface. I be happy for now.
Rich Taylor
I/SA - 321
Old 03-15-2014, 11:48 PM   #140
brent flynn
Lookin good! I always have run my Cal tracs in bottom hole... 1.440 60' out of old bracket engine and 4.11 gear... and 3550# on the starting line!
